Machinedesign Com Sites Machinedesign com Files Uploads 2013 11 Oscilloscopewatch
Who needs a calculator watch when you can get an oscilloscope on your wrist
Nov. 5, 2013
First came an oscilloscope small enough to fit in your hand. Now, from the same inventor, comes an oscilloscope built into an ordinary-sized wrist watch. Gabriel Anzziani in Sarasota, Fla. is trying to fund his 'wrist scope' project on Kickstarter. The gizmo is based on the same design as a palm-sized scope he has already devised. Specs include 256KB Flash, 16KB SRAM, 4KB EEPROM Sharp Memory LCD display, and 400-mAh Li-Ion battery rechargeable via a micro USB connector. The scope even functions as a logic analyzer with eight digital inputs that are 3.3 V / 5-V tolerant with a maximum sampling rate of 16 MSPS.
The scope has two analog inputs and a maximum sampling rate of 4 MSPS. Its analog bandwidth is 200 kHz and the input impedance is 1 MΩ. It even includes an arbitrary waveform generator with an analog bandwidth of 50 kHz.
In other words, the wrist scope might not be something you'd use to debug an Intel Core i7 processor design, but it certainly makes a statement about the person wearing it.
Lee Teschler | Editor
Leland was Editor-in-Chief of Machine Design. He has 34 years of Service and holds a B.S. Engineering from the University of Michigan, a B.S. Electrical Engineering from the University of Michigan;, and a MBA from Cleveland State University. Prior to joining Penton, Lee worked as a Communications design engineer for the U.S. Government.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
