Promo 644a9ab93a893 64b6d4241008a
2023 IDEA Awards: Electronic Components Nominees
July 18, 2023
Be sure to check out the other 2023 IDEA Awards category finalists.
Bourns, Inc. Power TVS Diode in DFN Package
Meeting the expanding need to improve reliability in today's AC and DC line protection applications, Bourns developed its PTVS1 and PTVS2 Power Transient Voltage Suppressors that offer 1 kA and 2 kA surge current protection. These two PTVS series come in a surface mount compact DFN package that give designers a much smaller solution with the same level of protection compared to existing PTVS devices that typically are available only in bulky over-molded or through-hole packages.
More Details
Phoenix Contact XTV Terminal Blocks with Push-X Technology
The XTV terminal blocks with Push-X technology can accommodate all types of conductors with direct wiring without the need for force or tools. A pretensioned contact spring lies at the heart of this new technology. The Push-X technology principle enables the connection of rigid and flexible conductors with or without ferrules.
More Details
Point2 Technology P1B120 Mixed-signal System-on-Chip (SoC)
Point2 Technology has introduced an impactful innovation with its P1B120 mixed-signal System-on-Chip (SoC), revolutionizing power efficiency in cloud data centers and 5G infrastructure. The P1B120 SoC enables 800G active electrical cables (AECs) with an unprecedented low power consumption of 5W per paddle card, marking a 40% reduction compared to existing solutions.
More Details
SiTime Elite RF SiT5376/SiT5377 Super-TCXOs
Elite RF SiT5376/SiT5377 Super-TCXOs Elite RF Super-TCXOs SiTime’s enable the higher bandwidths and lower latencies critical to modern and future 5G and satellite communications deployments. They’re a new class of MEMS-based, highly integrated temperature-controlled crystal oscillators built to withstand extreme environments.
More Details
Sun Hydraulics LLC ENERGEN
Composed of an integrated generator that converts power losses into useful energy, Energen delivers a robust approach to energy harvesting and check valve functionality. This solution coverts parasitic hydraulic losses into recovered electrical energy, and provides power generation in cartridge valves for sensors, solenoid valves and other electronics. ENERGEN also eliminates wires and harnesses for improved reliability and safety.
More Details
March 18, 2025
March 18, 2025
March 18, 2025
March 18, 2025
