Promo 644a9ab93a893 64b6c5e4a67f3
2023 IDEA Awards: Design and Operations Software Nominees
July 18, 2023
Be sure to check out the other 2023 IDEA Awards category finalists.
Quanterion Solutions Incorporated Nonelectronic Parts Reliability Data (NPRD) 2023
Failure rate reliability data is used to build reliability into designs, help meet requirements for a certain product or system, and more. However, finding accessible failure rate data can be challenging, especially if a company does not have in-house historical data on the component. The Nonelectronic Parts Reliability Data (NPRD) series is the solution engineers worldwide use to retrieve and analyze field reliability data.This new release, NPRD-2023, contains nearly 1.5 million data records for approximately 28,000 unique components.
More Details
Nullspace EM Simulation Software Toolset
Nullspace EM, an electromagnetic (EM) simulation software toolset, targets engineering teams designing RF devices in the aerospace, defense, communications and automotive fields. EM simulation is also important for antenna design and analysis in applications like near-field communications (NFC) for mobile payments as well as narrow-, wide- and multi-band antennas, reflectors, phased arrays, and radomes with FSS modeling.
More Details
ECM PCB Stator Technology PrintStator Motor CAD
PrintStator is ECM’s proprietary Motor CAD platform. It powers the design of PCB Stator electric motors that are smaller, quieter, and more energy and space efficient.  Motors designed via PrintStator—incorporating PCB Stator technology—are up to 70% lighter than conventional options, while achieving efficiencies as high as 96% and requiring just 20% of the raw materials.   
More Details
Nexperia Interactive Datasheets for MOSFETs
Nexperia’s interactive datasheets are a ground-breaking concept in the field of semiconductors. This stunning innovation transforms a datasheet from a static two-dimensional PDF document supplying exhaustive tables of product specifications and details about operating modes into an interactive, intuitive, multi-dimensional front-end for a circuit simulation tool.
More Details
Rockwell Automation FactoryTalk Design Hub Software
What if you could collaborate across your automation design team with software and project content that is always up-to-date and with powerful tools that scale as you need them? With FactoryTalk Design Hub software all of this is possible. By harnessing the cloud, companies can simplify software management while increasing productivity, speeding time to market and designing systems that cost less to build and provide more value over their lifetime.
More Details
Rockwell Automation FactoryTalk Logix Echo
FactoryTalk Logix Echo can help customers save significant engineering efforts and financial expenditure at every stage of a project from start to finish. Attention was dedicated to improving testing, giving users access to more than 20 variations of the 5580 ControlLogix platform at their disposal. FactoryTalk Logix Echo simplifies the emulator experience by providing users the opportunity to download directly to FactoryTalk Logix Echo without modifications.
More Details
