Yamato Introduces Checkweigher/Detector Combo System at Pack Expo 2015
On display at Pack Expo 2015, the Checkweigher/Fortress Metal Detector combination systems from Yamato feature precise load cell technology that delivers great accuracy and high-speed weighing. The integrated Fortress metal detector provides high-sensitivity metal detection for all ferrous, non-ferrous and stainless-steel metal contaminants. The Yamato/Fortress Combo is mounted on a single frame for efficient space savings and is an easy-to-clean design.
The combination checkweigher/metal detector merges two top technologies necessary for safety compliance in all food industries. IP69 and IP67 fabrication models are also available. Conveyors and belts can be cleaned and removed without tools.
The large color touchscreen contains distinct graphics and an intuitive LED light system that allows for higher visibility, all the while reducing power consumption. Yamato/Fortress Combo includes easy setup and troubleshooting, with an easy to learn multi-product memory software for fast changeovers.
