Inductive Proximity Sensors are IP67-Rated
Feb. 23, 2015
Rectangular compact inductive-proximity DC sensors from APS offer top or front sensing capabilities at ranges of 2.5 mm and 4 mm. The sensors come in two- or three-wire configurations. The high-frequency oscillation-type sensors, ranging from 10 to 30 VDC, are housed in unshielded polycarbonate and contain LED status indicators. Normally open or normally closed NPN, normally open PNP, or normally open NPN/PNP outputs are available.
APS, 3505 Hutchinson Road, Cumming, GA 30040, (770) 889-2858
