The RTDM12 Series of RTD temperature sensors have a molded (IP67) four-pin connector with M12 male thread. With a fast response time, the sensor is ideal for pressure-vessel applications, pressurized containers and applications needing a temperature sensor with an NPT mounting fitting.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (203) 359-1660
