Coolant-level sensor
Oct. 28, 2013
The next-generation CAP-300 Series coolant level sensor is designed to perform over long periods of time under the most rugged coolant applications.
The sensor requires almost no maintenance; tolerates coating, and is reliable in standby mode. Compatible with temperatures up to 257°F, the capacitive-based sensor is available with a variety of mounting types and electrical connections. It handles supply voltages from 9 to 32 Vdc.
Gems Sensors & Controls,One Cowles Rd., Plainville, CT 06062, (800) 378-1600, www.gemsensors.com
