Inclinometers and accelerometers
The DXI 100/200 Series of single and dual-axis inclinometers and the DXA 100/200 Series of single and dual-axis accelerometers feature a digital output with a resolution of 0.001°; provide both high precision and performance for tilt-sensing or acceleration applications; come standard with an EIA-RS485 and EIA-RS422 industry-standard outputs; and provide low noise an
May 20, 2013
The DXI 100/200 Series of single and dual-axis inclinometers and the DXA 100/200 Series of single and dual-axis accelerometers feature a digital output with a resolution of 0.001°; provide both high precision and performance for tilt-sensing or acceleration applications; come standard with an EIA-RS485 and EIA-RS422 industry-standard outputs; and provide low noise and high and long stability. These sensors are for use in applications including radar/antenna control, structural monitoring, platform leveling, linear acceleration/deceleration measuring, automatic train-position control systems, and seismic monitoring. Data sheets for both Series are available at http://jewellinstruments.com/wp-content/uploads/2013/03/DXI-100_200-Digital-Inclinometer.pdf and http://jewellinstruments.com/wp-content/uploads/2013/03/DXA-100_200-Digital-Accelerometer-FINAL.pdf.
Jewell Instruments LLC, 850 Perimeter Rd., Manchester, NH 03103, (603) 669-6400, www.jewellinstruments.com
