Transformers Feature Flexible, Open-Frame Design
Oct. 21, 2014
The Lighting Ballast Transformer Series from Innovative Power help regulate voltage to start lighting systems and regulate current for efficient operation
The Lighting Ballast Transformer Series from Innovative Power help regulate voltage to start lighting systems and regulate current for efficient operation. The transformers feature a flexible, scalable, open-frame design that is suitable for applications that require enhanced electrical performance, high reliability, long-life, and low lifecycle cost. They can be specified for applications from 50 to 2500 VA, 120 to 575 V to meet individual specifications. The series comes in a standard square open-frame package suitable for mounting which can be customized to meet temperature, humidity, and shock requirements.
Innovative Power, 165 Malbert St., Perris, CA 92570, 951-928-7700
