Machinedesign Com Sites Machinedesign com Files Uploads 2013 07 Cicoil Dg Flexx Sil
Flexible flat cables
July 11, 2013
The highly flexible Flexx-Sil flat cables provide premium current carrying capacity, excellent heat dissipation, consistent electrical characteristics, weight and space savings, and meet reliability requirements of continuous motion, welding robots and automation assembly systems. The crystal-clear, halogen and talc-free cables don’t require conduit for protection; will not wear, tear, or deform during a lifetime of more than 10 million cycles; are “self-healing” from small punctures; and withstand repetitive exposure to severe vibration, shock, flames (UL 94V-0 & FAA), electrical and mechanical stress, humidity, steam, weld spark, temperature extremes (–65 to 260°C), oil, water and many chemicals.Cicoil Corp., 24960 Avenue Tibbitts, Valencia, CA 91355, (661) 295-1295, www.cicoil.com
