Courtesy Mastercam
67658e3e2a0a16252864713e Img 8844 5
5 Machining Trends to Watch in 2025
Dec. 30, 2024
Implementing these five machining trends could give manufacturers a competitive advantage in 2025.
As 2025 approaches, manufacturers that embrace digital transformation—through advanced automation, IoT-enabled equipment and AI-driven insights—will be better equipped to enhance efficiency and remain competitive. Agility and interconnectivity will be key to successfully reimagining traditional processes. Here are five machining trends to watch in the year ahead.
1. Complex Machinery: Doing More with Less
Whether it’s five-axis lathes or advanced mills, the manufacturing industry is increasingly utilizing complex machinery to streamline workflows and reduce setup times. This eliminates the need to switch between machines, requiring less floor space, and can lead to faster production.
However, the adoption of sophisticated machinery is not without challenges. Their complexity demands advanced computer aided manufacturing (CAM) software and highly skilled programmers to operate them effectively. As this trend continues, the industry will likely see a greater emphasis on workforce training and software development. Despite these hurdles, the benefits of multitasking machinery with enhanced speed, precision and efficiency make them an attractive investment.
READ MORE: Innovation Through Collaboration in Manufacturing
2. Automation: The Rise of Artificial Intelligence (AI) in Manufacturing
A report by the National Association of Manufacturers highlights the extensive use of artificial intelligence (AI) tools across the industry, emphasizing their pivotal role in advancing modern manufacturing.
When it comes to automating programming methods, AI can help significantly reduce the time required. For example, where traditional methods might take 16 minutes to program a toolpath, AI can reduce that to just seconds. Each manufacturing shop operates with unique tools, setups and processes, however, which may require customization to ensure AI-generated toolpaths are accurate and safe.
While full automation of programming remains a distant goal, incremental advancements in automating micro-tasks—such as tool selection or fixture design—are already delivering measurable efficiencies. For manufacturers, leveraging AI involves balancing technological possibilities with practical constraints.
3. Turnkey Integrated Solutions
Historically, machinists and programmers took a hands-on approach, spending considerable time at machines to fine-tune settings and ensure optimal performance. In the coming year, expect to see increasing demand for out-of-the-box solutions that eliminate guesswork and reduce the need for manual intervention.
At the heart of this trend is the concept of interconnected systems that seamlessly communicate with each other. For instance, tools can be configured and validated virtually, ensuring the correct setup before any operation begins.
Digital twins take it a step further, letting programmers simulate and verify their code from the office before it’s ever run on a physical machine. This means fewer surprises and a higher chance that everything works as intended when it’s time to use the CNC machine. Together, bidirectional communication and automated validation significantly reduce human error, creating a smoother and more reliable workflow with fewer disruptions.
READ MORE: How 3D Printing Is Making Waves in Marine Rehabilitation
4. Additive Manufacturing: Expanding Possibilities
Additive manufacturing, such as 3D printing, is making waves in manufacturing. From intricate aerospace components to custom guitar necks, additive manufacturing allows fabricators to produce parts that were once deemed impossible or impractical.
Among the challenges are the high costs and a steep learning curve associated with the process. Figuring out the best materials and settings to use can call for extensive experimentation, often in collaboration with research institutions or under strict confidentiality agreements.
Despite these barriers, additive manufacturing is a field to watch closely with the global additive manufacturing market is expected to grow to more than $83 billion by 2030. As technology advances and costs decrease, it will become an increasingly viable option for mainstream manufacturing, especially for producing prototypes or parts with complex geometric shapes.
5. High-speed Machining: Faster, Lighter, Better
It is difficult to stay competitive without embracing new technologies. By using fast, light and low-pressure cuts, high-speed machining (HSM) increases material removal rates and reduces cycle times. Shops adopting HSM can achieve significant gains in efficiency and precision.
For shops already leveraging HSM, the focus is on fine-tuning processes and integrating the technology with other trends like AI and digital twins to further enhance productivity. Resistance to change remains a barrier for some manufacturers, but those unwilling to incorporate HSM risk being outpaced by the competition.
READ MORE: Beyond Traditional Machining: Hitting All the Right Notes in Custom Manufacturing
Looking Ahead
Success in 2025 and beyond will hinge on a willingness to adopt new technologies, reimagine traditional workflows and invest in workforce development. Unlike 20 years ago, when most newcomers went through formal apprenticeship programs, the younger generation of machinists are often jumping straight into the mix, learning on the job and adapting as they go.
With fewer young professionals pursuing traditional apprenticeships, more and more manufacturers will be looking to invest in turnkey solutions to bridge the skills gap. This shift also means the new generation of machinists isn’t necessarily tied to the traditional methods and habits, breaking away from a "this is how we’ve always done it" mentality. Digital natives entering the manufacturing space will help drive the industry forward with new, more efficient processes.
The goal remains unchanged: to produce better parts faster and more efficiently. By embracing complex machinery, harnessing AI for automation, implementing turnkey integrated solutions, exploring additive manufacturing and integrating high-speed machining, manufacturers can gain a competitive advantage. For those ready to adapt, the opportunities seem boundless in 2025.
Dave Miller | Manager of Sales Engineering, Strategic/Key Accounts, Mastercam
Dave Miller is the manager of sales engineering, strategic/key accounts at Mastercam where he’s worked for nearly a decade. Prior to his work at Mastercam, he worked as an engineer in the machining industry for shops across the midwestern U.S. He has a passion for the manufacturing industry that started at a young age. Fun fact: He was the winner of the 2004 Mastercam Wildest Part competition during his junior year of high school.
