RGB-1007-001 Series of lowprofile, red, green ,and blue LEDs are only 4.9 6.5 mm. They emit highintensity light in a 120° viewing angle and depending on color, intensities range from 230 to 750 mcd with current between 20 and 25 mA. The red diode’s wavelength is 635 nm. The wavelength of the green diode is 520 nm. Blue operates at 470 nm. A water-clear lens protects the diode array.
LEDtronics Inc., 23105 Kashiwa Court, Torrance, CA 90505, (800) 579-4875, ledtronics.com
