Pen for computing
Oct. 25, 2007
The FinePoint MPD-9xx Series of pen-based input devices contains battery-powered and battery-free pens and a digitizer behind the LCD screen communicating with the pen as it moves across the surface.
The FinePoint MPD-9xx Series of pen-based input devices contains battery-powered and battery-free pens and a digitizer behind the LCD screen communicating with the pen as it moves across the surface. The digitizer reports pen tip status, position, and sensitivity. The MPD-9xx digitizer board is said to be the thinnest on the market (1.2 mm) and houses all controller components in a strip down one side of the board. The board’s grid can be 7, 12.1, or 14.0-in. wide. Smaller formats are available for smartphone and PDAs.
InPlay Technologies Inc., 13845 N. Northsight Blvd., Scottsdale, AZ 85260, inplaytechnologies.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
