Endress+Hauser
Endress Hauser Flow Meters 5x7 65280ca38b040
AutomationDirect Expands Flow Sensor Line with Endress+Hauser Picomag Series
Oct. 12, 2023
The Endress+Hauser Picomag Series flowmeters are made to measure and monitor conductive liquids.
AutomationDirect has added the Endress+Hauser Picomag Series magnetic-inductive flowmeters to its range of flow sensors. They are designed to provide reliable and accurate measurement and monitoring of conductive liquids, including drinking and industrial water, with a minimum conductivity of 10 µS/cm.
Key features of the Picomag flowmeters include:
  • Simultaneous measurement
  • Flexible output options
  • User-friendly display
  • Wireless monitoring and configuration
  • Integration capabilities.
The Picomag series flowmeters enable simultaneous measurement of flow, temperature and volume, which allows the user to gather comprehensive data for liquid processes. Users also have the option to configure two selectable I/O points for analog current or voltage output, pulse or switch outputs, IO-Link connection or status inputs for totalizer reset; this aids compatibility and integration with existing systems.
READ MORE: Endress+Hauser 80 GHz Radar Sensors are Suitable for Extreme Process Conditions
Its large colored TFT display auto-rotates based on device orientation, and configuration parameters can be accessed by knocking on the device.
The flowmeter’s Bluetooth interface with free SmartBlue app enables seamless connectivity and control over the flowmeters. With a wireless connection distance up to 32 ft, the flowmeters are suitable for installation sites that are challenging to access. The IO-Link interface offers integration into established fieldbus systems. This interface allows direct access to process and diagnostics data as well as enabling on-the-fly device configuration.
Sharon Spielman | Technical Editor, Machine Design
As Machine Design’s technical editor, Sharon Spielman produces content for the brand’s focus audience—design and multidisciplinary engineers. Her beat includes 3D printing/CAD; mechanical and motion systems, with an emphasis on pneumatics and linear motion; automation; robotics; and CNC machining.
Email: [email protected]
LinkedIn: @sharonspielman
X: @MachineDesign
Facebook: Machine Design
YouTube: @MachineDesign-EBM
