181478534 © Илья Юрукин | Dreamstime.com
65b18d522ac572001dfcf495 Dreamstime 181478534
The Nuts and Bolts of Specifying Fastener Torque
Jan. 30, 2024
Consider materials for the bolt and housing, and the length of engagement to determine maximum torques.
Most engineers who deal with bolted joints are familiar with torque tables for SAE-grade bolts, but these are all too often used without regard for the yield strength of internal threads or the bolt’s length of engagement.
In some instances that can be a serious mistake. That’s because in static-bolting applications—assuming sufficient thread engagement—there are three cases to consider in determining maximum torque.
The first is when yield strength of the internal thread equals or exceeds the proof strength of the bolt, Si ≈ StSt, in which case the bolt may be fully torqued.
The second is when the yield strength of the internal thread is less than the bolt proof strength, Si<St, but because of the greater shear area of the internal thread the bolt can still be fully torqued. The final case has an internal-thread yield strength less than the bolt proof strength, Si < St, and even with the added shear area the internal threads have insufficient strength to support full torque.
In the first case, when the internal thread is as strong as the bolt and the length of engagement is at least 1.5 times the nominal bolt diameter, designers can use standard torque tables.
For the other two cases, where the internal thread material has a lower yield strength than the bolt’s proof strength, maximum allowable torque must be based on the length of engagement, bolt proof strength and yield strength of the internal thread. Here’s a method for calculating maximum bolt torque for all three cases.
Failure Modes
For a typical static bolted joint, engineers should evaluate three failure modes to determine the highest load that the bolted joint can withstand. These are:
  • Tensile failure of the bolt body.
  • Shear failure of the bolt threads.
  • Shear failure of the internal threads.
The lowest load that leads to failure determines the limiting torque. In the first instance, calculate the tensile-stress area of a bolt from ASME B1.1-1989 Appendix B using
In this equation,Dpb=Db– (2 3 3⁄8H), where Db = basic bolt diameter. Also, H = tan 60°(P/2), where 60° is the basic angle of the ASME thread form and pitch P = 1/threads per in.
The calculated value At is not based on the minimum root diameter. This value is slightly larger than the area defined by the root diameter to account for the added strength of the actual thread in the bolt cross section. A more conservative value would be the minimum root diameter of the bolt which disregards the area of the spiraling thread. For hollow threaded parts, use the minimum root diameter.
The allowable tensile load in the bolt based only on the tensile area is determined from Pt = St At ⁄Fs. For a typical static application, the factor of safety Fs = 1.25.
Next, evaluate shear stress in the bolt. Unlike the tensile area, length of engagement affects the bolt’s shear area. The shear area of the bolt is the effective area at the maximum minor diameter of the internal thread multiplied by the number of engaged threads. This is calculated as
The allowable tensile load in the bolt, based only on the shear area of the bolt threads, is then found from Ps = 0.5St As ⁄Fs.
An option is to calculate shear area using a 1-in. length of engagement. This gives shear area per unit length, and minimizes recalculation if the length of engagement changes. Multiplying the shear area per unit length by the length of engagement gives the actual shear area.
The final stress to evaluate is shear stress in the internal thread. As in a bolt, shear area of an internal thread is a function of the bolt’s length of engagement. The shear area of the internal thread is the effective area at the minimum major diameter of the external thread multiplied by the number of engaged threads. This is found from
The maximum tensile load in the bolt, based on the shear area of the internal threads, is calculated using Pi = 0.5Si Ai ⁄Fs. The lowest calculated allowable tensile load of Pt, Ps, and Pi should be used to determine maximum torque.
Determining Torque
The general equation for bolt load based on applied torque is T = KFiDb where K = torque coefficient. K is a function of the coefficients of friction and collar friction in the joint, and these are based on variables such as surface finish, coatings, and so on. Accepted coefficient values for both types of friction for steel-on-steel bolts is 0.15. With a coefficient of friction = 0.15, K ≈ 0.20 for all ranges of bolt sizes in both coarse and fine threads. For materials other than clean steel on steel, determine appropriate values from similar applications or by testing actual bolt and joint configurations. Typical K values are shown in the table.
When calculating loads and torques, the female thread always has a greater shear area than that of the bolt. This means there is a range where the base material yield strength is lower than the bolt’s, but the bolt can still be torqued to the maximum. In fact, with a length of engagement of 1.5Db, the range where full torque can be applied to lower-strength base material is quite large.
Specialized torque charts are a better option for taking advantage of this range without going through a series of calculations for each application. They also determine the correct torque and bolt load under derated conditions.
For instance, the accompanying chart for Grade 5 and 8 bolts was developed from a computer program that calculates thread dimensions and stress areas from the previous equations. However, the program differs from the calculations in two areas. One is that a stress concentration factor of 1.2 adjusts for unequal load distribution on the first engaged thread. The other is that external minor diameters are calculated by nontypical formulas provided in ASME B1.1-1989.
Scott Sauer was affiliated with Empire Engineering, Sunnyvale, Calif., at the time of this article's original publication.
June 27, 2025
June 25, 2025
June 25, 2025
