Developing Deception in Robots and Intelligent Machines
Jan. 4, 2013
It's a somewhat frightening idea - artificially intelligent machines that can deceive other devices, as well as people.
It's a somewhat frightening idea -- artificially intelligent machines that can deceive other devices, as well as people. By mimicking the deceptive behavioral patterns of squirrels and birds, researchers at the Georgia Institute of Technology have developed robots that are able to trick each other. Funded by the Office of Naval Research, team leader Professor Ronald Arkin suggests that the applications could be implemented by the military in the future. The work is highlighted in the November/December 2012 edition of IEEE Intelligent Systems.
After carefully reviewing biological research results, Arkin and his colleagues learned that squirrels gather acorns and store them in specific locations. The animal then patrols the hidden caches, routinely going back and forth to check on them. When another squirrel shows up, hoping to raid the hiding spots, the hoarding squirrel changes its behavior. Instead of checking on the true locations, it visits empty cache sites, trying to deceive the predator.
Arkin and Ph.D. student Jaeeun Shim implemented the same strategy into a robotic model and demonstration. The deceptive behaviors worked. The deceiving robot lured the “predator” robot to the false locations, delaying the discovery of the protected resources.
“This application could be used by robots guarding ammunition or supplies on the battlefield,” says Arkin, a Regents Professor in Georgia Tech’s School of Interactive Computing. “If an enemy were present, the robot could change its patrolling strategies to deceive humans or another intelligent machine, buying time until reinforcements are able to arrive.”
In a related scenario, Arkin and his student Justin Davis have also created a simulation and demo based on birds that might bluff their way to safety. In Israel, Arabian babblers in danger of being attacked will sometimes join other birds and harass their predator. This mobbing process causes such a commotion that the predator will eventually give up the attack and leave.
Arkin's team investigated whether a simulated babbler is more likely to survive if it fakes strength when it doesn't exist. The team’s simulations, based on biological models of dishonesty and the handicap principle, show that deception is the best strategy when the addition of deceitful agents pushes the size of the group to the minimum level required to frustrate the predator enough for it to flee. He says the reward for deceit in a few of the agents sometimes outweighs the risk of being caught. Similarly, in a 2010 study, Arkin and research engineer Alan Wagner studied how robots could use deceptive behavior to hide from humans or other intelligent machines.
“In military operations, a robot that is threatened might feign the ability to combat adversaries without actually being able to effectively protect itself,” explains Arkin. “Being honest about the robot’s abilities risks capture or destruction. Deception, if used at the right time in the right way, could possibly eliminate or minimize the threat.”
From the time of the Trojan Horse, deception has always played a role during wartime and an entire Army field manual is dedicated to its use and value within the battlefield. However, Arkin admits there are serious ethical questions regarding robot deception behavior with humans.
“When these research ideas and results leak outside the military domain, significant ethical concerns can arise,” cautions Arkin. “We strongly encourage further discussion regarding the pursuit and application of research on deception for robots and intelligent machines.”
For more information, visit Georgia Tech.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
