Diffused ML7-Series sensors are housed in 31
3
113
23-mm profiles and offer slotted mounting holes. Two lens positions handle side and end sensing. Crosstalk immunity is standard, letting units mount side-by-side without interference. IP67-rated housings are standard as is single-pushbutton, onetouch rapid setup. Pepperl-Fuchs,
1600 Enterprise Pkwy., Twinsburg, OH 44087,
(330) 486-0001, www.pepperlfuchs.com
