COMPACT OPERATOR PANEL
The display is IP65 protected on the front and has 43
20-character resolution, 16 function keys, and 12 LEDs. There are two versions, the first with 16 digital inputs and outputs. Its inputs can partly double as counter and encoder inputs. The second carries four analog inputs and outputs, plus eight original inputs and outputs. The PP15 can access additional decentralized I/O points or servodrives via a CAN interface for applications that need more I/O points.B&R Industrial Automation Corp.,
1325 Northmeadow Pkwy., S-130, Roswell, GA 30076,
(770) 410-3206,
www.br-automation.com
Dec. 23, 2024
Dec. 23, 2024
