Designed to move up to 175 lb, it is a four-axis, floor-level palletizer capable of running single or dual-line applications at a rate of up to 10 cycles/min. The K-Bots compact 62
3
104-in. footprint allows for pallet sizes of up to 48 3
48 in. and unit loads up to 72-in. high. It is dual function, serving as a palletizer and depalletizer. The operator interface is programmed with predefined pack patterns, simplifying changeover. The machine incorporates protective features on its motors and power-encoder cables that promote long life. Schneider Packaging Equipment Co., Box 890, 5370 Guy Young Rd., Brewerton, NY 13029, (315) 676-3035, schneiderequip.com.
