Tab washers - Boker's Inc.
June 9, 2011
The tab washers come in multiple configurations and materials.
Tab washers lock parts into place in applications requiring extreme heat conditions or heavy vibrations. The washers come in internal tab, external tab, internal/external tab, multiple internal/external tab, and locking tab designs.
Outside diameters range from 0.080 to 6.000 in., and multiple inside diameters and thicknesses are available. The washers come in 2,000 metallic and non-metallic materials including low-carbon sheet steel, spring steels, stainless steel, aluminum, brass, copper, nickel silver, ABS, acetal, polyester, nylon, nylon MD, polycarbonate, fiber, polyethylene, and NEMA-grade laminates.
Boker's, Inc., 3104 Snelling Ave., Minneapolis, MN 55406, (800) 927-4377, www.bokers.com
Jessica Shapiro
