Infrared spot-curing power meter - IRPhotonics
Aug. 7, 2010
The compact power meter works with iCure thermal spot curing systems.
The iCure P200 power meter is for measuring optical power from thermal spot curing systems. The plug-and-play tool's power monitor and power detector work with iCure AS200 thermal spot curing systems in manufacturing environments. The compact meter measures power up to 15W and can calibrate multiple systems using a preset power set-point.
IRPhotonics, 7 Cobblestone Dr., Hamden, CT 06518, (877) 340-6982, www.icure-irphotonics.com
Jessica Shapiro
