LED-cure radiometer - Dymax Corp.
June 21, 2010
The radiometer accurately measures energy dosage.
The ACCU-CAL 50-LED radiometer accurately measures the intensity and dosage of LED cures, including energy levels emitted from 3-mm, 5-mm, and 8-mm lightguides and LED flood lamps. The unit has a spectral sensitivity range of 350 - 450 nm and measures intensity between 1 mW/cm2 and 40 W/cm2 using a photo-sensor assembly designed for protection from high temperatures. The unit is CE Marked and available globally.
DYMAX Corp., 318 Industrial Lane, Torrington, CT 06790, (860) 482-1010, www.dymax.com
Jessica Shapiro
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
