New product: Conformal coating adhesive
Feb. 2, 2010
The conformal coating for printed circuit boards is also a UV curing adhesive.
 UV10LV, a clear, non-conductive, UV-curing conformal coating, protects electronics from moisture, dust, chemicals, and temperatures up to 300°F. It has a refractive index of 1.55 and a volume resistivity of 1014 ohm/cm.
The adhesive is low viscosity and cures quickly with room-temperature exposure to UV light. Cure continues after initial exposure and is not oxygen-inhibited. It has a shelf life of 6 months at 70oF in original unopened containers.
Master Bond, 154 Hobart St., Hackensack, NJ 07601, (201) 343-8983, www.masterbond.com
