Water-treatment controllers
Aug. 1, 2012
CDCN13 Series high-accuracy controller systems from Omega Engineering Inc. are available in NEMA-4X wall-mount enclosures.
• Systems feature conductivity/TDS control with a choice of bleed programs; temperature monitoring; makeup and bleed water-meter totalizers; Langelier saturation index; six feed programs for four chemical additives; probe-failure indication alarm • Programmable controller enables complete chemical automation and handles cooling tower, boiler water, industrial process water, food processing, drinking water, and wastewater-treatment applications
(800) 826-6342 • omega.com
Diaphragm Pumps Critical in Degassing for Chromatography, Inkjet Applications
Effective degassing is essential for maintaining accuracy and performance in chromatography and inkjet systems. Discover how diaphragm pump technology ensures reliable, bubble...
How Changing Inlet Conditions Affect Diaphragm Pump Performance
Inlet conditions can significantly impact the efficiency and reliability of diaphragm pumps. Learn how variations in pressure, temperature, and media composition influence performance...
