Pneumatic SOLUTIONS
Dec. 1, 2005
Twin-rod air cylinders Twin-rod cylinders achieve precise, non-rotating linear motion with less than 1/3 degree of rotation for rod alignment and eliminate
Twin-rod cylinders achieve precise, non-rotating linear motion with less than 1/3 degree of rotation for rod alignment and eliminate endplay for guided motion.
FEATURES & BENEFITS
  • Rectangular body simplifies mounting, saves space, and achieves precise angles
  • Offers twice the force of comparable cylinders
  • Single and double-acting models with strokes from ½ to 4 in.; six bore sizes from ¼ to 1¼ in.
  • Integral magnets mount sensors on three sides
HUMPHREY PRODUCTS CO.
Kalamazoo, Mich.
(269) 381-5500
www.humphrey-products.com
Circle 243
Rack-and-pinion actuation
Rack-and-pinion rotary actuators suit compressed air environments, including those that are filtered, lubricated, or non-lubricated.
FEATURES & BENEFITS
  • Available in 90°, 180°, 270°, and 360° rotation angles
  • Operating pressures from 21 to 145 psi
  • Cylinder sizes from 32 to 125 mm; available as double-acting, non-magnetic or magnetic, or with adjustable cushioning
  • Torques from 1.2 to 51 Nm/bar
IMI NORGREN INC.
Littleton, Colo.
(303) 794-2611
www.norgren.com
Circle 244
