Product spotlight: Lubes and seals
March 1, 2006
Elastomeric sealing F-treated FKM elastomers offer a permanent low coefficient of friction surface that cannot be washed away. FEATURES & BENEFITS Material
Elastomeric sealing
FEATURES & BENEFITS
  • Material properties are protected beneath the surface of molded shapes
  • Stable properties; little difference between original and aged elastomer
MINNESOTA RUBBER
Minneapolis, Minn.
(612) 927-2121
www.mnrubber.com
Circle 111
Air mist lubricant
Synmist is a high film strength, synthetic lubricant used in centralized air-mist lubrication systems.
FEATURES & BENEFITS
  • ISO grades 32, 46, 68, 100, 150, 220, 320, and 460 available
  • Reduces bearing vibrations; is compatible with most synthetic and all mineral air mist oils
  • Atomizes to eliminate large, unwanted wet oil droplets
  • Rapidly demulsifies from water to displace moisture from bearing surfaces
  • Does not cause wax buildup or congeal at low temperatures
ROYAL PURPLE LTD.
Porter, Texas
(281) 354-8600
www.royalpurple.com
Circle 112
Infrared lubrication system
PurgeX infrared lubrication system combines PurgeX positive displacement pump with programmable logic and infrared sensing for dispensing the right amount of lubrication accurately on a moving target.
FEATURES & BENEFITS
  • Up to 0.012 in.2 fluid output
  • PLC specifies frequency and duration of fluid application; infrared sensors verify target
  • Tested to 360 million cycles
  • Syncronizes fluid dispensing with speed and number of chain links
  • 3-way solenoid, PLC, pumps, and 24-Vdc power supply contained in NEMA 12 enclosure
OIL-RITE CORP.
Manitowoc, Wis.
(920) 682-6173
www.oilrite.com
Circle 113
Electrical connector lubricant
RheoTemp 761G performs above the polyalphaolefin (PAO) heat barrier of 125°C at a cost less than silicone or fluorinated oils.
FEATURES & BENEFITS
  • Reaches temperatures of 175°C
  • Reduces connector insertion force
  • Maintains electrical resistance after 10 cycles of mating and unmating
  • High wear protection and material compatibility; low water washout and oil separation
NYE LUBRICANTS INC.
Fairhaven, Mass.
(508) 996-6721
www.nyelubricants.com
Circle 114
