Gauge precision vital to system's success
Feb. 1, 2007
The MT 1271 length gauge used here has a measuring range of 12 mm and recommended measuring steps of 0.5 m to 0.05 m. With its high system accuracy and
The MT 1271 length gauge used here has a measuring range of 12 mm and recommended measuring steps of 0.5 µm to 0.05 µm. With its high system accuracy and small signal period of 2 µm, the gauge is also used in precision measuring stations and testing equipment. It has a ball-bush guided plunger, which allows high radial forces. MBF's new system allows field applications with light and confocal microscopes, and with files from electron microscopes and scanning tomographic instruments.
For more information, visit www.heidenhain.com or www.mbfbioscience.com.
