Product Spotlight: Locking devices
Nov. 1, 2007
Shaft collars S25FB9 (brass) and S25FY9 series (303 stainless steel) shaft collars incorporate built-in bearing shim spacer and Fairloc integral hub fastener.
Shaft collars
Features & benefits
  • Inch and metric sizes fit shafts from 0.12 to ¾ in. (3 to 20 mm) in diameter
  • O.D.s from 0.433 to 1.496 in. (11 to 38 mm)
  • Fairloc fastener prevents marred shafts, permits frequent phase, timing, and position adjustment; adds positive metal-to-metal fastening strength along both hub sections
Sterling Instrument
(516) 328-3300
www.sdp-si.com
Circle 151
Retaining devices
Adjustable Tangent-Lok devices secure power transmission and other mechanical assemblies.
Features & benefits
  • Infinite position lock; ability to properly preload assembly
  • Eliminate need for keyed shaft, lockwasher
  • Install with PAS wrench or SLAS socket
  • Carbon steel with alloy hex-head set screws
  • Manufactured with SAE inch threads and ISO metric threads
Whittet-Higgins Co.
(401) 728-0700
www.whittet-higgins.com
Circle 152
Corrosion-resistant shaft collars
Smooth-bore shaft collars include corrosion-resistant screws made from 316 stainless steel.
Features & benefits
  • One and two-piece clamp-style designs with bore sizes from ⅛ to 2-in., 3 to 50-mm in metric series
  • Clamp-style collars do not mar shafts; higher holding power, more easily adjustable than setscrew collars
  • Single-point faced for perpendicularity, proper alignment
  • Face-to-bore relationship ensures components are properly positioned and not tilted on shaft
Ruland Manufacturing Co. Inc.
(508) 485-1000
www.ruland.com
Circle 153
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
