Pneumatic microslide
The 8-mm-wide DGSC pneumatic microslide from Festo Corp. is suited for installation in small spaces, as in electronics production and small-parts assembly.
• Design features a preloaded ball-bearing cage, enabling positioning accuracy of 0.01 mm • Applications include handling operations in automatic test-equipment systems, simultaneous loading/unloading of multiple chips or ICs in and out of the test process, attaching small screws, and marking printed-circuit boards with data-matrix code • Slide features low breakaway torque and travels jerk-free starting at 15-psi pressure • Mechanical interfaces simplify integration into machines • Various mounting and air-connection options available
(800) 993-3786 • festo.com
