Companion Spotlight: Synchronous Pulleys
April 1, 2008
Timing belt drives Self-guiding Conidrive timing belt drives feature the N10 belt-pulley system with an offset conical projection profile on the bearing
Timing belt drives
Self-guiding Conidrive timing belt drives feature the N10 belt-pulley system with an offset conical projection profile on the bearing surface to ensure positive fit without pulley flanges, even for narrow belts.
Features & benefits
  • Nondirectional 10-mm pitch belts offer same meshing in both directions of travel
  • Polyurethane, reinforced with steel tensile-cords for strength
  • 500 to 1.000-mm lengths; belt stock also available in 50-m lengths
  • Single, double, triple-row types featuring nonchordal action
  • Fairloc integral hubs create a transverse wedge that remains attached to the solid portion of the hub on one side
Stock Drive Products
(516) 328-3300
www.sdp-si.com
Circle 151
Timing pulleys
Customized timing pulleys meet specific design requirements to minimize inertia, with special machining, tolerances, and finishes.
Features & benefits
  • Aluminum, steel, stainless steel, delrin, nylon, etc.
  • All pitch types XL, L, H, XH, T2.5, T5, T10, T20, AT5, AT10, AT20, HTD3, HTD5, HTD8, HTD14, STS3, STS5, STS8, GT5, GT8, and more
  • Available in wide widths, with or without flanges or self-retracting V grooves
  • Mount via keyways or set screws; machined to accept Taper-lock and QD bushings, and keyless locking devices
Onvio LLC
(866) 685-0404
www.onviollc.com
Circle 152
Stainless-steel sprockets
Stainless steel sprockets for synchronous belt drive systems carry high horsepower ratings.
Features & benefits
  • Taper-Lock bushing system allows for easy sprocket installation and removal; resist rust, foam degreasers, and caustic washdown solutions
  • With Poly Chain GT Carbon synchronous belts, provide a low-maintenance alternative for roller chain systems
  • Don't release contaminants associated with lubricated sprockets and chains
  • PowerGrip rubber synchronous belts are available with steel, sintered steel, grey iron, and ductile iron for durability
Gates Corp.
(303) 744-1911
www.gates.com/carbon
Circle 153
Synchronous belt drives
Synchronous Plus drives combine a high-capacity belt with a flexible, dual-sprocket design with both metric and standard-tapped holes.
Features & benefits
  • 50% more horsepower capacity than standard construction high-torque drives
  • Belt dimensions from 5 to 20-mm pitch
  • Allow for use of smaller, lighter sprockets
  • Helically wound fiberglass cords, chemically treated and designed for length stability, flexibility, and tensile strength for shock loads
  • Precise tooth formation and accurate spacing for uniform transmission of power with resistance to tooth jump and shear
TB Wood's
(717) 264-7161
www.tbwoods.com
Circle 154
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
