Spotlight: Linear feedback
Oct. 1, 2006
Miniature linear encoders SR-P40, SR-P200, and SR-P1000 ultra-small encoders use light reflection-diffraction technology to make alignment and adjustment
SR-P40, SR-P200, and SR-P1000 ultra-small encoders use light reflection-diffraction technology to make alignment and adjustment easier than permeable types.
Features & benefits
  • Resolution of 2 µm with maximum speed of 4 m/sec (P40); 1 to 4 µm with maximum speed of 4 m/sec (P200); and 0.32 to 0.08 µm with maximum speed of 1.5 m/sec (P1000)
  • Quartz glass with length of 15 to 1,000 mm or film linear scales with length of 15 to 200 mm
  • Grating pitch of 80 µm
Canon U.S.A. Inc., Semiconductor Div., Encoder Products Group
Lake Success, N.Y.
(516) 328-4611
www.usa.canon.com
Circle 245
Easily-mountable linear encoders
LIDA 200 encoders control low-end linear operations in an exposed package.
Features & benefits
  • Same graduations, accuracy, and reliability of 400 series
  • Grating period of 200 µm for analog systems (for digital systems, signal periods of 5, 1, and 0.5 µm) available
  • Higher speeds (10 m/sec) than LIDA 400; offers higher contamination resistance
  • Mount by scale tape that comes in rolls with reference marks
Heidenhain Corp.
Schaumburg, Ill.
(847) 490-1191
www.heidenhain.com
Circle 246
Position transducer
Series M general-capability position transducer gives long displacement range, multiple mounting options, and size efficiency.
Features & benefits
  • Maximum range of 85 in.
  • Choice of analog (voltage divider or rheostat) or digital (quadrature) sensors
  • Reduced displacement cable fleet angle increases repeatability and reduces cable overlap
  • RoundAbout cable exit for 360° × 360° orientation eliminates need for transducer relocation or pulleys in a 3D environment
Space Age Control
Palmdale, Calif.
(661) 273-3000
www.spaceagecontrol.com
Circle 247
Industrial Ethernet sensor
R-series EtherCat sensor provides high-speed position feedback and data transfer for industrial Ethernet.
Features & benefits
  • Resolution to 1 µm, speeds to 0.2 mm/sec, and update time of 1 µsec (independent of stroke)
  • Synchronizes clock signals for high-speed deterministic control
  • Use with one to five position magnets; customize to document position, velocity, acceleration, and smart functionality
  • LEDs indicate normal operation, programming mode, magnet not detected, missing external interface signals, and insufficient or out-of-range input power
MTS Systems Corp., Sensors Div.
Cary, N.C.
(919) 677-2314
www.mtssensors.com
Circle 248
High-performing encoder
Mercury II encoders offer high resolution, accuracy, and speed in a robust design.
Features & benefits
  • Next-generation optical design and SmartPrecision II electronics
  • Selectable resolutions from 5 µm to 1.2 nm linear
  • Tape accuracy of ±70 nm and ±5 µm/m short and long travel; glass offers ±25 nm short travel and better than 1, 1.5, and 2.5 µm for varying scales
  • Three times faster than other encoders
MicroE Systems
Natick, Mass.
(508) 903-5000
www.microesys.com
Circle 249
