Rugged safety mats
May 19, 2011
NSD pressuresensitive electrical safety mats can be customized for irregular angles, contours, notches or wiring locations to accommodate specific machine-guarding applications. The maximum size of a single mat is 72 × 144-in
NSD pressuresensitive electrical safety mats can be customized for irregular angles, contours, notches or wiring locations to accommodate specific machine-guarding applications. The maximum size of a single mat is 72 × 144-in. long and it can be designed in any configuration.
Two controllers are offered: A standalone NEMA-12 metal-box controller with system diagnostics, and a DIN-rail controller with system diagnostics. The DIN-rail model offers a separate remote status-display panel that can be externally mounted on a control-panel door to provide machine operators and front-line supervisors immediate system status and diagnostics when the controller is mounted inside the machine control panel.
Pinnacle Systems Inc.
Box 100088
Pittsburgh, PA 15233
(800) 569-7697
www.pinnaclesystems.com
© 2011 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
