High-flow direct-mount valve - Parker Fluid Control Div.
Oct. 7, 2010
The Namur high-flow direct-mount solenoid valve features a Namur mounting pattern and high-flow rates.
The Namur high-flow direct-mount solenoid valve features a Namur mounting pattern and high-flow rates from 1.2 to 3.0 Cv. A spring return allows fail-safe operation during power loss, and a screened exhaust nut protects valve function during outdoor use. An O-ring seal design increases sealing force at higher pressures and offers less breakaway resistance at lower pressures.
Featuring an anodized aluminum body, stainless-steel spool, and brass internal parts, the valve mounts in any position on a Namur interface. The valve operates at 30 to 150 psi, fluid temperatures of 32 to 122°F, and are offered with class F DIN and Class H hazardous location coils.
Parker Fluid Control Div., 95 Edgewood Ave., New Britain, CT 06051, (860) 827-2300, www.parkerfluidcontrol.com
© 2010 Penton Media, Inc.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
