SL, RL, and FL right-angle gearboxes have 1:1 spiral-bevel inputs and precision planetary outputs producing gear ratios from 3:1 to 100:1. The gearboxes come in several frame sizes with output torques ranging from 6 to 100 Nm. Backlash is as low as 12 arc‑min.
The gearboxes mount to NEMA and Metric/IEC servos and stepper motors. An optional PL flange allows the compact installation of the reducer body inside the output-timing pulley.
Onvio, 20 Northwestern Dr., Salem, NH 03079, (866) 685-0404, www.onviollc.com
