Pressure transducers - Transducers Direct
Sept. 24, 2010
TDH-40 pressure transducers provide accuracy of 0.4% in both hydraulic and pneumatic systems
TDH-40 pressure transducers provide accuracy of 0.4% in both hydraulic and pneumatic systems and incorporates an M12, 9.4 DIN electrical connection. Series 316 stainless-steel housing permits use in harsh environments and protects against water intrusion. It is rated to 10,000 psi, and is powered by a 12 to 36-Vdc supply. A 0.25 -in.-NPT pressure port is standard.
Transducers Direct, 12115 Ellington Court, Cincinnati, OH 45249, (513) 583-9491,
www.transducersdirect.com
© 2010 Penton Media, Inc.
Kenneth Korane
Ken Korane holds a B.S. Mechanical Engineering from The Ohio State University. In addition to serving as an editor at Machine Design until August 2015, his prior work experience includes product engineer at Parker Hannifin Corp. and mechanical design engineer at Euclid Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
