Braided polyester sleeves - Tyco Electronics Corp
Sept. 9, 2010
The Raychem Versaflex polyester sleeves, for mechanical protection of wire and cables.
The Raychem Versaflex polyester sleeves, for mechanical protection of wire and cables, feature a braided design that allows for easy expansion and contraction of the sleeves while retaining tension.
The RoHS-compliant sleeves conform to irregularly shaped products or substrates without the need to heat shrink, do not retain heat or moisture, and are abrasion resistant. The sleeves come in flame-retardant and nonflame-retardant versions.
Tyco Electronics Corp., 1050 Westlakes Dr., Berwyn, PA 19312, (610) 893-9800, www.tycoelectronics.com/help
© 2010 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
