Receptacle certified as secondary conduit seal - Turck
Sept. 9, 2010
The 7/8-16UN minifast explosionproof feed-through receptacle is CSA certified as a secondary conduit seal to prevent gas migration or as a boundary seal, when used with a certified cordset. Fully potted in a durable 316 stainless-steel housing, the receptacle is designed to withstand 2,000 psi of pressure and IEC IP67 protected against liquid ingress when a mating connector is attached. The receptacle installs directly into 1/2-14 NPT threaded conduits and is rated for 600 V and 9 A. When used as a secondary conduit seal, the receptacle is limited to 30 V and 600 mA.
Turck, 3000 Campus Dr., Plymouth, MN 55441, (800) 544-7769, www.turck.us
© 2010 Penton Media, Inc.
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
