Motor mount and gearbox - GAM Gear LLC
Aug. 13, 2010
The LSK and EPL-H are said to be the industry’s first-ever motor-mounting kit and planetary gearhead that can specifically be adapted to Festo actuators.
The LSK is a customized mount designed to connect any motor to a linear actuator. The unit comes in multiple sizes and includes the coupling and mounting hardware.
The EPL-H is a hollow-output planetary gearbox that mounts directly to an actuator or motor. The EPL-H comes in three frame sizes.
GAM Gear LLC, 901 E. Business Center Dr., Mt. Prospect, IL 60056, (888) 426-7177, www.gamweb.com
