Right-angle gear drives - Zero-Max Inc.
Aug. 13, 2010
Crown gear drives provide directional motion in all types of power-transmission systems.
Crown gear drives provide directional motion in all types of power-transmission systems. The quiet-operating drives are sealed from contaminants and feature hardened Class 10 spiral-bevel gears that are permanently mounted to the nonmagnetic stainless-steel shafts with locking pins.
The drives are available in standard two and three-way models with 1:1 and 2:1 speed ratios with shaft diameter combinations of 3/8, ½, 5/8, and ¾ in. Precision-hardened and ground ball bearings provide smooth and quiet operation at speeds to 2,000 rpm.
Zero-Max Inc., 13200 6th Avenue N, Plymouth, MN 55441, (800) 533-1731, www.zero-max.com
© 2010 Penton Media, Inc.
