Lithium button-cell retainer - Keystone Electronics Corp.
July 23, 2010
A new lithium button-cell retainer is suitable for 4.8‑mm ML414 micro batteries.
A new lithium button-cell retainer is suitable for 4.8‑mm ML414 micro batteries. Designed for miniature electronics such as watches, hearing aids, calculators, keyless door-entry fob’s, memory backup, and small toys, the retainers are engineered with reliable spring tension for low-contact resistance while firmly securing the battery within the retainer.
The retainers are made of phosphor-bronze with solder tails outside the retainer body to facilitate visual inspection of the solder joints. Gold plating for lead-free and low-temperature reflow soldering is available.
Keystone Electronics Corp., 31-07 20th Rd., Astoria, NY 11105, (800) 221-5510, www.keyelco.com
© 2010 Penton Media, Inc.
