Right-angle worm gearboxes - Groschopp Inc.
April 26, 2010
The new line of NEMA right-angle (RA) worm gearboxes have hollow output shafts that allow for right, left, or dual-shaft configurations.
The new line of NEMA right-angle (RA) worm gearboxes have hollow output shafts that allow for right, left, or dual-shaft configurations. Features of the gearboxes include 5:1 to 100:1 ratios, 1/15 to 10-hp input power, and 5 to 6,000-lb/in. torque. Available in 40 to 110‑mm sizes, the gearboxes are made of high-thermal-capacity die-cast aluminum housings for efficient heat dissipation. All housings are powder coated, for a durable corrosion-free finish.Groschopp Inc., 420 15th St. NE, Sioux Center, IA 51250, (800) 829-4135, www. groschopp.com
