The Large Super Air Nozzle maximizes entrained airflow and force while reducing compressed-air use and noise. The aerodynamic design of the zinc-aluminum-alloy nozzle directs the air to a single point of convergence, delivering 23 lb of strong blowing force when mounted 12 ft away from the target (reportedly 30 times that of ordinary air nozzles). It is suitable for blowing heavy materials over long distances, and wide-area blow-off, drying, and cooling applications. Typical sound level reduction is 20 dBA, and air consumption is 460-scfm at 80 psig.Exair Corp., 11510 Goldcoast Dr., Cincinnati, OH 45249, (800) 903-9247, www.exair.com
