Linear stage features plug n’ play operation - Servo2Go.com Ltd.
March 25, 2010
The motorized T-LSM Series linear stages have high thrust and speed capabilities and a compact size.
The motorized T-LSM Series linear stages have high thrust and speed capabilities and a compact size. The computer-controlled devices are stand-alone units requiring only a standard 15-V power supply. A potentiometer knob permits smooth manual control; a full turn gives it maximum speed. The slides connect to the RS-232 port of any computer and can be daisy-chained with up to 254 units/chain. The unit’s six-pin mini DIN cables allow direct interconnection between units in close proximity; longer distances require a cable extension.
Features include 25 to 200-mm travel, 100-N maximum centered load, built-in controller, high speed, thrust, and accuracy; and mounts in an XYZ configuration without any additional hardware.
Servo2Go.com Ltd., 4001 Kennett-Pike, Suite #134-583, Greenville, DE 19807, (877) 378-0240, www.servo2go.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
