Induction motor comes in three efficiency levels - SEW-Eurodrive Inc.
March 8, 2010
The new DR motor modular system lets users specify application-specific options.Coating and sealing options keep the motor protected in wet environments in a wide range of temperatures.
The new DR motor modular system lets users specify application-specific options.Coating and sealing options keep the motor protected in wet environments in a wide range of temperatures.The motor meets international energy standards and comes in three efficiency levels: DRS Standard Efficiency (IE1), DRE High Efficiency (IE2), and DRP Premium Efficiency (IE3). Other customizable options include brake size (up to three sizes for each motor), cost-optimized encoders, and mounting type.The motor is equipped with a manual brake release, automatic or lockable, that is field adjustable to one of four different mounting positions. A built-in encoder, installed between the endshield and fan, is connected at the terminal box so it can be easily retrofitted. SEW-Eurodrive Inc., 1295 Old Spartanburg Highway, Box 518, Lyman SC 29365, (864) 439-7537, www.seweurodrive.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
