The HEC-1000-E-R Harsh Environment Controller allows for programmable intelligence under less than ideal conditions due to a sealed, watertight enclosure with pluggable connectors. The standard enclosure is submersible to 3 ft and is screw and subplate mountable. The controller is programmed using EZ Ladder software, which supports ladder diagram with function block programming. The unit features an extended temperature range of -40 to 80°C.Features include 8 to 32-Vdc input power, I/O includes six 8 to 32-Vdc inputs; two 40-kHz high-speed counters; two 10-bit analog channels rated 0 to 20 mA; and six digital/PWM outputs rated to 3 A with automatic overcurrent safety and programmable status monitoring for each. Divelbiss Corp., 9778 Mount Gilead Rd., Fredericktown, OH 43019, (800) 245-2327, www.divelbiss.com
Dec. 23, 2024
Dec. 23, 2024
