Epoxy works to 600°F - Master Bond Inc.
March 5, 2010
The EP46HT-1 epoxy has a continuous operating temperature range of –100 to 550°F and withstands intermittent exposures up to 600°F.
The EP46HT-1 epoxy features a continuous operating temperature range of –100 to 550°F, withstands intermittent exposures up to 600°F, and a glass-transition temperature of over 235°C. Designed to withstand severe and repeated thermal cycling, the epoxy is easy to apply and cures rapidly at elevated temperatures. The 100%-reactive epoxy contains no solvents or diluents. Additional features include exceptional physical strength, dimensional stability, and chemical resistance, as well as excellent adhesion to metals, glass, vulcanized rubbers, and most plastics.Master Bond Inc., 154 Hobart St., Hackensack, NJ 07601, (201) 343-8983, www.masterbond.com
