Module turns industrial enclosures into flange-mount disconnect enclosures - Rittal Corp.
Feb. 25, 2010
The TS8 disconnect module turns single-door TS8 modular freestanding industrial enclosures into flange-mount disconnect enclosures.
The TS8 disconnect module quickly turns any single-door TS8 modular freestanding industrial enclosure into a flange-mount disconnect enclosure. The module installs in place of a standard TS8 sidewall and interlocks with the enclosure door to function the same as a conventional disconnect door. The module is 4-in. wide and eliminates the need for a typical disconnect door, which is almost twice that size. The module comes in four different sizes with the consistent 4-in. width, heights of 71 or 79 in., and depths of 16, 20, and 24 in.The TS8 module’s reversible configuration lets it be used on either the enclosure’s right or left side. The module is compatible with disconnect handles from the most well-known manufacturers.Rittal Corp., 1 Rittal Place, Urbana, OH 43078, (800) 477-4000, www.rittal-corp.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
