Fan heater for enclosures - Omega Engineering Inc.
Feb. 25, 2010
The CR027 fan heater maintains minimum operating temperatures in enclosures to help prevent failure of electronic components.
The CR027 fan heater maintains minimum operating temperatures in enclosures to help prevent failure of electronic components due to condensation and corrosion. The DIN-rail-mountable, CE-compliant unit adjusts to ambient temperature and has an adjustable thermostat and control light. It is equipped with a built-in temperature limit in case of fan fire.Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (203) 359-1660, www.omega.com
