Solenoid-operated direction-control valves - Continental Hydraulics
Feb. 24, 2010
The VSNG6 solenoid-operated directional-control valve features a compact design, making it suitable for mini-power pack, mobile, and agricultural applications.
The compact design of the VSNG6 solenoid-operated directional-control valves features reduced solenoid dimensions, making the valves suitable for mini-power pack, mobile, and agricultural applications. The valve’s high-strength cast-iron body features wide internal passages to minimize flow-pressure drop. The valves are available in three or four-way designs with interchangeable spools and different porting configurations. Features of the valves include maximum flow rates of 13.2 gpm with maximum pressure to 4.060 psi, dc or rectified current wet armature solenoids with interchangeable coils, and five different types of electrical connections.Continental Hydraulics, 5505 W. 123rd St., Savage, MN 55378, (952) 895-6400, www.continentalhydraulics.com
