Sensor features single cable connection - Turck Inc.
Feb. 18, 2010
A single cable connects two high-accuracy cylinder position sensors, reducing connection points, wire costs, and installation time.
A single cable connects two high-accuracy cylinder position sensors, reducing connection points, wire costs, and installation time. The BIM-UNT dual sensor detects long and short-stroke cylinders in stamping, sorting, conveying, and other material-handling applications. The single-cable design is beneficial in applications where multiple cylinders are installed. The dual sensor’s sensitivity is useful for detecting both the home and end positions of a piston during longer stroke cycles.Turck Inc., 3000 Campus Dr., Minneapolis, MN 55441, (800) 544-7769, www.turck.us
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
